drcos
Feb 09, 2022Initiate
WAX202 - Disable WPS in AP mode?
There is no option I can see to disable WPS on this router. Any help?
- Feb 10, 2022
According to the fine documentation, it isn't, indeed.
RaghuHR it's more than obscure that in the year 2022 there are no controls to disable WPS in general, WPS by PIN, and WPS by push button. Definitively controls our customers expect from what is sold as a business AP, even if it's just the "essential" features class..
schumaku
Feb 10, 2022Guru - Experienced User
drcos
Feb 10, 2022Initiate
Not the answer I wanted, but the answer I expected.
Supposedly it will fight off WPS attacks by itself, and hopefully I never have to find out.
- schumakuFeb 10, 2022Guru - Experienced User
Depending on the installation location, with the WPS PIN problem addressed for a long time, I'm much more concerned about the physical button.
drcos wrote:Supposedly it will fight off WPS attacks by itself, and hopefully I never have to find out.
Well, it's not supposed to allow brute force WPS PIN attacks of course.
