RanTakria
Oct 17, 2024Aspirant
WAX202 5GHZ only mode takes 10+ mins until it works.
Hi folks! I use a WAX202 in AP mode for my wireless PCVR setup. For this I only use the 5 GHz mode. Since I only need the WiFi when I'm playing with the VR glasses, I otherwise turn it off. It wo...
- Oct 17, 2024
Clearly caused by the regulatory requirements for DFS on 5 GHz Not much you can do against,except of reconfigure that AP to a channel-set nor requiring DFS in your regulatory area.
schumaku
Oct 17, 2024Guru - Experienced User
RanTakria
Thank you so much, this should be the issue, im 6km away from a sports airfield!
