Dnomis
Mar 30, 2025Aspirant
WAX202 as an AP problem
I have a Billion BiPAC 8800AXL R2 as my main router. I have 2 SSID subnets set up lets call them ABC and ABC-Guest ABC uses 192.168.1.xxx and ABC-Guest uses 192.168.2.xxx allowing access to the In...
Dnomis
Mar 31, 2025Aspirant
Many thanks for your reply. I am trying to get my head around the last part but I think I got lost around where the Trunk port was introduced...
I have tried to map it out on the attached picture but I think I got lost...
What am I missing?
What am I missing?
schumaku
Mar 31, 2025Guru - Experienced User
There will be two different Ethernet links required, one will be the normal LAN, the other the Guest LAN.
