Popo99
Sep 21, 2022Aspirant
WAX202 in bridge mode lost wireless radio
I've got two WAX202 used to extend my network. One is set up as a AP, wired to the base router. This one works fine, as both a switch and a wireless broadcaster. The second one I set up in bridg...
- Sep 22, 2022
so it basically amounts to confusion. Both on your part and on how different manufacturer's define bridge mode.
For netgear, bridge mode is where it acts as just a bridge between 2 devices. It doesn't rebroadcast. so basically it uses its wireless as a bridge and gives the end user the ability to use the ethernet ports on the "bridge" device.
Some other companies use bridge mode for repeater/extender mode.
The WAX202 doesn't have repeater/extender mode. Either access point mode, router mode, or bridge mode.
Options?
You could always hardwire it in using powerline or moca adapters.
Or you could look at returning it and getting a wireless extender since thats what your trying to use it for.
Popo99
Sep 22, 2022Aspirant
Just to add a note. Netgear does seem to have some WAP products, like this one
NETGEAR Wireless Desktop Access Point (WAC104) - WiFi 5 Dual-Band AC1200 Speed | 3 x 1G Ethernet Ports | Up to 64 Devices | WPA2 Security | Desktop | MU-MIMO | Supports 3 SSIDs | 802.11ac
Sep 22, 2022Guru - Experienced User
They do have some. Not arguing that. Just not the version you have.
