nightowl2k2
Aug 12, 2022Aspirant
WAX202 rouge 2.4 GHz endpoint
I have a couple WAX202 WiFi routers and in both cases I am seeing a rogue 2.4Ghz endpoint that shows up after a short amount of time of the router being online. I have seen this happen on 2 devices...
Aug 12, 2022Guru - Experienced User
Are you using any ios devices? If so, disable icloud relay and private mac/ip address.
nightowl2k2
I am using IOS/Mac devices but my Mac is on the 5Ghz band and not on the 2.4Ghz band. So, that part does not seem to make sense here.
- nightowl2k2Aug 12, 2022Aspirant
I can also disconnect my Mac and I still see an endpoint connected to the 2.4Ghz radio. So that also clears the Mac Internet relay function.
- plemansAug 15, 2022Guru - Experienced User
and you have no other mac/ios devices?
Is bandsteering enabled on the WAX? if so, it might have been connected to the 2.4ghz. It doesn't drop off immediately.
