Burpingchimp's avatar
Burpingchimp
WAX202 Same SSID
I recently purchased the WAX202 Ap to allow me to use the ethernet ports and extend the wifi in my summerhouse.   However, when i went through the set up i had to create a new SSID and password whi...
  • schumaku's avatar
    schumaku
    Jul 12, 2023
    In AP mode, you can configure one to three different SSIDs, all are connecting to the same network. You are free to configure the SSID to the same name, the same security settings and the same pre-shared key you might have configured on your ISP or other wireless router.
    Or should you be confused due to the predefined default admin SSID?
ProSupport for Business
