icalkins
May 03, 2022Tutor
WAX206 fails in AP mode
I returned the first WAX206 thinking it was faulty, but the replacement has the same issue. When I configure it in 'router' mode, it works fine. However, when I change the mode to 'access point', it ...
rschilt
Aug 15, 2022Guide
Hi,
I recently purchased a WAX206 and I'm having similar issues as you are having when setting up in AP Mode.
Other responses to your original ticket seem to be getting AP Mode and Bridge Mode mixed up.
Did you ever get this resolved?
Robert
icalkins
Aug 16, 2022Tutor
I appreciate the work of the community moderators here, but I'm happy to respond. The issue was me, not the WAX206. I was going modem-to-WAX206 and trying to run it in AP mode. I was told it can't be done like that. I need to go modem-to-router-to-WAX206 if I want to run it the WAX206 in AP mode. My bad.
- rschiltAug 16, 2022Guide
Thanks icalkins
I am running router (modem) => WAX206 in AP Mode.
This worked fine for me except when "Turn on Access Control" and "Block all new devices from connection" were enabled on WAX206 - the WAX206 would lock up (same as what you reported initially) which required a reboot of WAX206 for it to work again.
When this was happening my router / modem was a pfSense appliance.
I have since switched my router /modem to an IPFire appliance - with Access Control restrictions set on WAX206 and the lock up error on WAX206 does not happen.
Robert
ps: apologies to the moderators for overacting yesterday.... must be a challenge at times keeping order in the house.
- icalkinsAug 16, 2022Tutor
Just to clarify, when I say "modem" in my posts, I mean modem-only. I do not mean modem / router.
Technically my setup is the same... modem (Fibre to ETH NTU) => router (IPFire appliance) => AP (WAX206).
With the setup using pfSense as the router.... I still had the WAX206 hang issue - needing a reboot to reset the connection.
Changing the router to IPFire now seems to have resolved the WAX206 hang issue.
Anyway.... the WAX206 is a great Wireless AP - and we both have working solutions.
