icalkins
May 04, 2022Tutor
WAX206 fails in AP mode
I returned the first WAX206 thinking it was faulty, but the replacement has the same issue. When I configure it in 'router' mode, it works fine. However, when I change the mode to 'access point', it ...
icalkins
Aug 16, 2022Tutor
Okay, but your set-up isn't the same as the one I was attempting. Mine was Modem (CM1200) => Router (WAX206) in AP mode. I'm not being argumentative here, just making sure other readers see why my set-up wasn't working. I needed another router in between if I wanted to run the WAX206 in AP mode.
rschilt
Aug 17, 2022Guide
Fair enough.... all good.
