simeoncran
Aug 08, 2022Aspirant
WAX206 poor 2.4GHz performance
I'm getting very variable and poor ping times to my ESP32 and ESP8266 devices connected to the WAX206. It doesn't seem to matter how close the devices are. This is in an apartment building with lots ...
- Aug 08, 2022
You kind of hit on your problem with the fact that you live in an apartment.
2.4ghz is much more sensitive to interference and has less available channels to use. When a device is broadcasting on 2.4ghz, the other devices on that same channel can't broadcast. You even put that the wax206 you have in an area with less interference, doesn't have an issue.
More than likely the reason it works well for a very short time when changing the channel is that most 2.4ghz routers tend to be set on auto. You'll get that brief period where the router is changing channels that its stops connecting and then works really fast for a bit as the other devices in the complex pickup that it switched. Then it drops back to longer pings as they go back to broadcasting.
Apartment complexes are horrible for 2.4ghz signals. I ran into that same issue a lot until I moved into a detached home. Even then I have some higher ping/latencies because I can still pickup quite a few 2.4ghz signals.
Aug 10, 2022Guru - Experienced User
20 second latency is a bit much but a lot is also going to depend on the smart plug. Some are going to be faster than others based on their coding and how they're checking on the "if its their" turn to broadcast. (simplified)
simeoncran
Aug 10, 2022Aspirant
I have similar smartplugs in both locations. In the non-apartment location they respond to commands from their web interface immediately, and in the apartment they typically take about 10 seconds, but as much as 20+ seconds although occasionally they're quick. That's also what I see just pinging them. It doesn't matter what time of day it is or what channel I force the router to. That surprises me as I'd have thought that the responsiveness would improve when the humans were asleep.
Constantly pinging a smartplug every 0.2 seconds makes it respond immediately, but it doesn't help if the pings are more than 0.3 seconds apart. That might suggest that the smartplug is going to sleep after a quarter second and taking ages to wake up, but when I move the smartplug to the non-apartment location it always responds immediately.
Also a pair of smart cameras that were working great when I first installed the WAX206 have given up connecting. They're old, so maybe they just all died within a few days of each other.
Presumably the other residents in the building are also seeing the same poor performance and are putting up with this crazy latency, or maybe it is the WAX206 after all. Next step is to swap the routers between the 2 locations and see if there is any difference. Lucky I bought 2! đŁ
- simeoncranAug 17, 2022Aspirant
ACTUALLY SOLVED
I ended up buying a 3rd WAX206 (don't have time to be swapping out routers that are in service) and that solved the problem. But I also learned that the firmware is flaky on these routers. Factory resetting the seemingly faulty device got it working again.
Even something as simple as switching these devices to AP mode then back to router mode renders them unusable (the wired connections stop working), but factory resetting fixes that too.
Oh well, at least they're cheap and have good range. Hopefully they'll keep running now.
