aposull
Jul 19, 2023Aspirant
WAX206 sticky 2.4ghz
I have recently purchased a WAX206 AP Very disappointing device so far. The biggest issue with it is that my phone is constantly connecting to the 2.4ghz channel and is never redirected to 5ghz. B...
aposull
Jul 20, 2023Aspirant
Thanks all for the replies/suggestions.. the phone is a Samsung S21FE
The region on my device is set to Europe (correct in my case)
The wifi mode on the 5ghz channel is set to “Up to 2400 MBps (80MHz) (11ax, HT80, 1024-QAM)”
I have smart connect disabled but I will enable it and to see if it affects the band choice.
As an aside.. I have a WAX204 AP in a different location in the house (also with smart connect disabled) and it has never had this issue 😕
schumaku
Jul 20, 2023Guru - Experienced User
With smart connect disabled, you have the option to configure two different SSIDs, one for each band. This should make the difference visible easily.
Worst case, do a factory reset and reconfig from scratch. If the 5 Ghz band SSID still does not show up on different wireless clients, don't hesitate to get in touch with the Netgear support via Https://my.netgear.com/
