WhateverDude
Oct 28, 2024Aspirant
wax214 AP - slow speeds
We just got a new broadband line in which should provide around 900-1000Mb/s throughput. I also have the ISP's router's WiFi active to compare speeds. ISP's router using WiFi I am getting 900...
BrianL
Oct 29, 2024NETGEAR Moderator
Hi WhateverDude,
Welcome to the community!
Is the AP locally or Insight managed? Are you connecting to the 2.4GHz or 5GHz? Have you tried using other WiFi channels?
Kind regards,
BrianL
WhateverDude
Oct 29, 2024Aspirant
Just locally managed and installed in my home, connected with a PoE injector. I first had it on my old cisco PoE swktxh and wondered if using a PoE injector would help but did not change much.
Currently the AP is connected directly to the ISP's router via a PoE injector.
- BrianLOct 29, 2024NETGEAR Moderator
Hi WhateverDude,
Thanks for responding. Were these new tests done with your main (Router) SSID disabled? Does all WiFi clients have the same behavior?
Kind regards,
BrianL
- WhateverDudeOct 30, 2024Aspirant
Yeah, I tried a few clients such as phone, pc and laptop with similar speeds.
I probably was not that pragmatic with my testing while both AP's were up.
- BrianLNov 01, 2024NETGEAR Moderator
Hi WhateverDude,
Let's have this issue investigated. Kindly contact our support team to create a ticket and prepare the following.
1. AP Logs
2. Network Topology
3. Placement, Distance, Security Setting, Channels used.
4. Wireless Client/s used including driver versions.
Kind regards,
BrianL
