WhateverDude
Oct 28, 2024Aspirant
wax214 AP - slow speeds
We just got a new broadband line in which should provide around 900-1000Mb/s throughput. I also have the ISP's router's WiFi active to compare speeds. ISP's router using WiFi I am getting 900...
WhateverDude
Oct 29, 2024Aspirant
Just locally managed and installed in my home, connected with a PoE injector. I first had it on my old cisco PoE swktxh and wondered if using a PoE injector would help but did not change much.
Currently the AP is connected directly to the ISP's router via a PoE injector.
BrianL
Oct 29, 2024NETGEAR Moderator
Hi WhateverDude,
Thanks for responding. Were these new tests done with your main (Router) SSID disabled? Does all WiFi clients have the same behavior?
Kind regards,
BrianL
- WhateverDudeOct 30, 2024Aspirant
Yeah, I tried a few clients such as phone, pc and laptop with similar speeds.
I probably was not that pragmatic with my testing while both AP's were up.
- BrianLNov 01, 2024NETGEAR Moderator
Hi WhateverDude,
Let's have this issue investigated. Kindly contact our support team to create a ticket and prepare the following.
1. AP Logs
2. Network Topology
3. Placement, Distance, Security Setting, Channels used.
4. Wireless Client/s used including driver versions.
Kind regards,
BrianL
- schumakuNov 03, 2024Guru - Experienced User
The WAX214 is configured for the maximal available 80 MHz wireless bandwidth? Assuming it's a WAX214v2 hardware variant, since the WAX214(v1) is limited to a much to small nuber of channels - sufficient for a single AP on a single location only.
- ErwinLJan 09, 2025NETGEAR Moderator
Hello WhateverDude
And welcome to the NETGEAR Community! 🙂
Were you able to get a hold on support team and open a case for your issue? Please provide us update if possible.
Have a lovely day,
Erwin
Netgear Team
