Jimmybilt1
Jan 05, 2023Tutor
WAX214 AX1800 No Internet
Flashed firmware to the latest 2.1.1.3 Connected to Netgear 5 port PoE switch GS305P v2 Router is TP Link AX3000 When I try to connect wirelessly to the WAX214, I get "No internet, secured" Tried...
- Jan 05, 2023It appears to be the WAN port on the PoE switch. I connected my PC to the switch and was unable to get internet so I rma'd the unit and should have a replacement Saturday
Jan 05, 2023Guru - Experienced User
If you direct connect the AP to the tplink router, does it work?
That's where i'd start.
I'd also look at checking in the tplink if it's issuing an iP address to the AP when its connected.
