Jimmybilt1's avatar
Jan 05, 2023
WAX214 AX1800 No Internet
Flashed firmware to the latest 2.1.1.3 Connected to Netgear 5 port PoE switch GS305P v2 Router is TP Link AX3000 When I try to connect wirelessly to the WAX214, I get "No internet, secured" Tried...
  • Jimmybilt1's avatar
    Jimmybilt1
    Jan 05, 2023
    It appears to be the WAN port on the PoE switch. I connected my PC to the switch and was unable to get internet so I rma'd the unit and should have a replacement Saturday
ProSupport for Business
