Jimmybilt1
Jan 05, 2023Tutor
WAX214 AX1800 No Internet
Flashed firmware to the latest 2.1.1.3 Connected to Netgear 5 port PoE switch GS305P v2 Router is TP Link AX3000 When I try to connect wirelessly to the WAX214, I get "No internet, secured" Tried...
- Jan 05, 2023It appears to be the WAN port on the PoE switch. I connected my PC to the switch and was unable to get internet so I rma'd the unit and should have a replacement Saturday
Jan 05, 2023Guru - Experienced User
when you're connected to the wax, are you able to log into it?
Does the tplink show it connecting?
- Jimmybilt1Jan 05, 2023Tutor
I found a 12 volt power adapter and connect it to the AP instead of using the PoE switch. It now works.
Thanks!
- plemansJan 05, 2023Guru - Experienced User
Makes me curious if the switch is putting out enough power. That AP only needs 18watt and the switch is supposed to put out more than that. Something else putting a load on that switch?
- Jimmybilt1Jan 05, 2023TutorIt appears to be the WAN port on the PoE switch. I connected my PC to the switch and was unable to get internet so I rma'd the unit and should have a replacement Saturday
