chrisonline
Apr 28, 2022Tutor
WAX214 captive portal
Is there a way to get a captive portal with the WAX214 Business WLAN Access Point?
- May 05, 2022
My apologies. But this is a product limitation for the WAX214. You can also share this in our Ideas Exchange for Business board so that our engineering team may include it on our future firmware release but this is not guaranteed.
John
NETGEAR Community Team
chrisonline
Apr 29, 2022Tutor
JohnC_V
May 04, 2022NETGEAR Employee Retired
Hi chrisonline,
As per checking the datasheet, it does not show that the WAX214 supports captive portal.
John
- chrisonlineMay 04, 2022Tutor
Yes I know but I have tought I can do this with the Insight.
But the WAX214 is not Insight compatible.
So is there any other alternative to have a captive portal?- JohnC_VMay 05, 2022NETGEAR Employee Retired
John
