Thomasss
Feb 24, 2022Follower
WAX214 constant losing CONFIG_ONLY_SSID network
Hey, I have a Wifi 6 AX1800 Dual Band PoE Acces Point Model WAX214. When connecting to the CONFIG_ONLY_SSID network for setup, the aplogin.net screen opens up in my browser. However the connection...
schumaku
Feb 25, 2022Guru - Experienced User
Alternate to using the wireless access to start with, I would check the router for the WAX214 LAN IP address. This should be visible under the router attached devices list or the like, compare the MAC address on the access point label. While connected to your network by Ethernet or the wireless (no the WAX214), use the browser and access from the browser using the IP address discovered above, and start the configuration from here.
