NemakoMD
Aug 06, 2021Follower
WAX214 not connecting to wifi because I cannot change SSID and password
WAX214 not connecting to wifi because I cannot change SSID and password.
antinode
Aug 06, 2021Guru
> WAX214 [...]
https://community.netgear.com/t5/x/bd-p/business-wireless-for-business
> [...] not connecting to wifi [...]
Huh? What, exactly, is not connecting to what, exactly, when you do
what, exactly?
> [...] because I cannot change SSID and password.
"cannot" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
What, exactly, are you trying to change, and what's stopping you from
doing it?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read?
