SrDocDiva's avatar
SrDocDiva
Unable to log into http://192.168.100.1 because "Your connection to this site is not private"
I've searched through this community and haven't found a solution that works for me. I saw that a few people (such as, tmbrwolf ) have had the same problem which was solved by resetting the modem - I've tried that, but it didn't change anything.  Can someone please help (ATTENTION NETGEAR, this is your product!).  Thank you in advance.
- I just purchased a brand new CM1200 cable modem the other day.
- My desktop PC (Windows 10) is attached directly to the modem via an ethernet cable (at this point there's no wifi router in my setup).
- This modem has been activated with Xfinity and I do have internet connectivity [hence, I can post this message here].
Per the User's Manual for the CM1200 modem, under Chapter 2, "Manage Your Network" -> "Log In to the Cable Modem" -- it says the following;
[These instructions can also be found here:
https://kb.netgear.com/000059644/How-do-I-log-in-to-my-NETGEAR-cable-modem]
To log in to the cable modem:
1. Connect a computer to your cable modem.
You can connect a computer to your cable modem using the following methods:
• Connect a computer to your cable modem using an Ethernet connection.<-- I'M USING THIS OPTION
• Connect a WiFi router to your cable modem using an Ethernet connection, and
then connect a computer to your router using a WiFi or Ethernet connection.
2. Launch a web browser. <-- I'VE TRIED DIFFERENT BROWSERS; CHROME, MICROSOFT EDGE, AND INTERNET EXPLORER
3. Enter http://192.168.100.1.
A login window opens.
4. Enter the admin user name and password.
The user name is admin. The default password is password. The user name and
password are case-sensitive.
The BASIC Home page displays. <-- THIS NEVER DISPLAYS!
I CANNOT GET PAST THE LOGIN WINDOW. THE MESSAGE ON THE LOGIN WINDOW SAYS, "Your connection to this site is not private".  CLICKING ON THE "Sign in" BUTTON MERELY REFRESHES THIS WINDOW.
WHEN I CLICK ON THE "Cancel" BUTTON, I GET "HTTP 401 Unauthorized".
I've tried pushing the RESET on the modem - with the coax cable disconnected as well as with it connected (as per tmbrwolf)
And, as noted above, I've tried different browsers.
I get the same result.
No joy.
  • After calling Eero, and then calling Xfinity..  I called Netgear, explained the problem and they opened a case #, then transferred me to technical support. I was on hold for nearly 25 minutes. So, I hung up and called them back (same number I called before). In the meantime, they closed my case # ! Then they gave me a new case #, transferred me to Technical Support *again*. After another 20 minutes, I hung up.
    Given what I paid for this new modem and the new Eero router (total over $1,000.00), these hassles are not worth it.
    SOLUTION:  Returned this modem and the new router to Best Buy for a full refund.  For the cost of Xfinity's monthly modem/router rental, I can rent for years.
    > Get over it.
    Back 'atcha there antinode.  Your arrogrant attitude is extremely unhelpful.
    Don't bother replying.  I'm out of here.  Bye!
  • > Unable to log into http://192.168.100.1 because "Your connection to
       It's common to get complaints from a modern web browser when you use
    the modem/router's management web site, because the browser is worried
    about your sending some user credentials over an unencrypted/insecure
    link ("http://" instead of "https://").  The easy thing to do is ignore
    the warning, and proceed.  Presumably, you're talking to your own gizmo
    on your own LAN.  If someone can overlisten to that local traffic, then
    you're already in big trouble.
    > I CANNOT GET PAST THE LOGIN WINDOW. [...]
       You need to tell your web browser to let you continue using the "not
    private" connection.  Then you need to specify the correct user name and
    password.  Specifying bad (including no) credentials leads to that "401"
    error.
    • SrDocDiva's avatar
      SrDocDiva
      antinode  Thank you for replying.  Unfortunately, I don't understand your explanation.
      I'm trying to access Netgear's modem/router's management website.  As I wrote in my initial comments, I just bought this new Netgear Modem "CM1200" - so yes, I suppose you could call it my gizmo (not Xfinity's gizmo) and I'm reading the documentation provided by Netgear.  In that documentation, it tells me to go to http://192.168.100.1.  When I read the documentation from the manufacturer and explicitly follow their directions, I expect things to work as they say it should.
      How do I tell my web browser to let me continue using the "not private" connection?  For example, where in Chrome's setting would I find that option?  And specifying the correct username and password?  Huh?  I am using the username and password given as per Netgear's documentation.
      Regardless, in the meantime I decided to move on to other tasks - like installing my new WI-FI router and getting all of the various devices attached to it (thermostat, etc).   My LAN is now all set up.  It's that pesky http://192.168.100.1 that I can't get to.  In another thread someone wrote that they were able to access that website from their smart phone.  Well, I tried and I can't log on to http://192.168.100.1 from either my iPhone or my iPad, let alone my PC.
      By the way, my PC remains hard wired to the modem (Netgear CM1200) via an ethernet cable.  The internet is working fine (hence, my abililty to write this comment).  I am thinking of changing the set up to attach my PC directly to the router instead of the modem.
      Again, thank you for your reply but it doesn't solve the issue I reported.  I still want to access the modem management website as per Netgear.  And, I'm still concerned about that message, "Your connection to this site is not private".   I am unable to proceed with the modem management.  <-- this is the problem.
      Exactly.  That's the kind of thing Netgear users, like myself, want to prevent.
      Question about you - are you employed by Netgear or are you a knowledgable user ("guru") who's here volunteering his/her time to help people?
      Thank you again.
      • antinode's avatar
        antinode
        Guru
        > private" connection? [...]
           I'd assume that there's some option/control/button on the page
        (pop-up?) with the "not private" complaint.  (Or just ignore it?)
        > [...] where in Chrome's setting [...]
           I don't know if there's a global setting; I'd expect a per-site
        choice.  I seldom use Chrome.  In Firefox (Mac, at least, but I believe
        Windows, too), it seems to remember a previous choice.  I go straight
        into my D7000, but it does show a lock icon with a red slash through it
        (roll-over text: "Connection is not secure").
           Around here, the "Sign in" box on Chrome says, "Your connection to
        this site is not private", but, when I put in the correct credentials,
        it works as expected.  (With "/!\ Not Secure" before the URL.)  Whether
        I've already been down this path with Chrome on this Mac is uncertain.
        > [...] It's that pesky http://192.168.100.1 that I can't get to. [...]
           What happens when you try?
           "can't" is not a useful problem description.  It does not say what
        you did.  It does not say what happened when you did it.  As usual,
        showing actual actions (commands) with their actual results (error
        messages, LED indicators, ...) can be more helpful than vague
        descriptions or interpretations.
        > an ethernet cable. [...]
           That's probably bad.  With typical residential service, you get one
        external IP address, so you get to connect _one_ device to your modem,
        not more.  That one device would typically be your router (WAN/Internet
        port), and all your client devices would be connected to that router
        (LAN ports).  If you connect multiple devices to a modem, it's likely
        that only one will get a useful Internet connection (and your
        external/public IP address).  If your computer is not getting a valid IP
        configuration (address, et c.), then not getting through to
        "192.168.100.1" is the least of your problems.
           The CM1200 User Manual is less emphatic than it should be about the
        limitations/restrictions on the use of this modem's multiple Ethernet
        ports, but there are some hints.  For example:
              Note: Your cable modem comes with a plug that covers the LAN 2, 3,
              and 4 ports.  You can remove the plug to connect a router that
              supports Ethernet port aggregation.  For more information, see the
              cable modem's user manual.
           You must, I claim, admire the the quality of documentation which
        tells you to read the manual which you are already reading.
        > [...] And, I'm still concerned about that message, "Your connection to
        > this site is not private". [...]
           Get over it.
        > prevent.
           Which part of "already" was unclear?
        > [...] are you employed by Netgear [...]
           No.  Netgear employees have an "N" icon by their names.
        > [...] or are you a knowledgable user [...]
           Opinions on that vary widely.
