flopma
Jun 14, 2022Aspirant
wax214 transmit power
Hello all, Just finished setup up a business access point, WAX214, upgraded the firmware to current latest, which is v 2.1.1.2. I would like to lower the transmit power. The documentation say...
JeraldM
Jun 17, 2022NETGEAR Employee Retired
Welcome to the community!
Please disable Auto RF to be able to change the transmit power of the AP in dBm.
For your reference, kindly check the image below:
JeraldM
NETGEAR Community Team
flopma
Jun 19, 2022Aspirant
Hey JeraldM , thx for your reply.
The device is running firmware v 2.1.1.2 and as you can see below, I don't have this option displayed.
- JeraldMJun 21, 2022NETGEAR Employee Retired
Hi flopma,
Just to confirm, your location is Luxembourg and have you tried changing the Country/Region as well?
Also, the latest FW version is v2.1.1.3, might as well consider upgrading its firmware if possible.
JeraldM
- flopmaJun 21, 2022Aspirant
I've updated to latest which was released yesterday it seems. Still I don't have the transmit power in dB.
Should I reach support? Since the documentation is saying I should see it in dB...
Thx
