flopma
Jun 14, 2022Aspirant
wax214 transmit power
Hello all, Just finished setup up a business access point, WAX214, upgraded the firmware to current latest, which is v 2.1.1.2. I would like to lower the transmit power. The documentation say...
flopma
Jun 19, 2022Aspirant
Hey JeraldM , thx for your reply.
The device is running firmware v 2.1.1.2 and as you can see below, I don't have this option displayed.
JeraldM
Jun 21, 2022NETGEAR Employee Retired
Hi flopma,
Just to confirm, your location is Luxembourg and have you tried changing the Country/Region as well?
Also, the latest FW version is v2.1.1.3, might as well consider upgrading its firmware if possible.
JeraldM
NETGEAR Community Team
- flopmaJun 21, 2022Aspirant
I've updated to latest which was released yesterday it seems. Still I don't have the transmit power in dB.
Should I reach support? Since the documentation is saying I should see it in dB...
Thx
- schumakuJun 22, 2022Guru - Experienced User
RaghuHR please clarify the difference between the documentation and the Web UI. Thank you!
- flopmaJun 22, 2022Aspirant
https://www.downloads.netgear.com/files/GDC/WAX214/WAX214_WAX218_UM_EN.pdf mentions page 68 points 5 and 6.
My current web interface shows me Full, Half and Quarter.
Regards
