gregz83
Feb 24, 2021Follower
WAX218 Mesh
Can you mesh 2 WAX218 together using different channels?
Feb 24, 2021Guru - Experienced User
As a mesh like Orbi? no.
Can you set it with the same ssid? Sure. The wax218 supports fast roaming so devices should roam like in an enterprise environment if the device supports fast roaming.
