mario_ed
Sep 21, 2023Guide
WAX220 initial configuration does not work
Today I bought two WAX220 (AX4200) access points and I tried to configure them. I connected two Ethernet with PoE. Network WAX220xxxxxxxx-CONFIG-ONLY came in. But when I tried to connect using the p...
schumaku
Sep 21, 2023Guru - Experienced User
The printed SSID (WAX220xxxxxxxx-CONFIG-ONLY) and wireless password, also from the QR code (including the SSID, the WPA2-PSK information, and the default WiFi access password), is valid for the initial configuration and for about 20 minutes only - and does not grant access to the LAN/network and the Internet. Following the factory default/reset again, It's intended only to open a Web browser session (on modern clients automatically, with some delay, to accept the self-signed certificate). Once you have defined your own password during the initial configuration, the printed password is no longer valid anymore.
Honestly, a little bit lost where you are struggling with the attempt initial connection and configuration.
- mario_edSep 21, 2023Guide
Thanks for your prompt reply.
Yes, your description matches also my understanding about how it should work. The problem is simple: the password written in the sticker does not work neither the QR code. I tried from my iPhone (QR code and manually) and from my PC (Dell XPS17), none of them works. I am getting a error message saying that the password is incorrect. I am stuck. Both brand new devices have the same problem.
How can I troubleshoot?
- DavidGoSep 21, 2023NETGEAR Expert
Hi mario_ed
Could you try one more factory reset like this > press the Reset button for at least 11 seconds.
Once the AP reboots, please try to connect to the WAX220xxxxxxxx-CONFIG-ONLY SSID once again, ensuring to enter the password correctly i.e. make sure to use uppercase or lowercase accordingly.
If the password printed on the label is still not accepted, please try (all in lower case): sharedsecret
Can you also please send me the serial numbers of the 2 WAX220's thru private message.
Regards
DavidGo
- schumakuSep 21, 2023Guru - Experienced User
Trying the said password for establishing the wireless association (connection) [what would be correct] -or- for the admin login [this will be queried during the first connection to the https based Web UI] ?
At this point, it's intentional the wireless connection does not allow connecting to the LAN or the Internet. Once configured accordingly, this limitation is void.
With DavidGo's assistance, I'm convinced you are able to get your two WAX220 configured and operational.
What hits my eye is that the WAX220nnnnnn-CONFIG-ONLY password is not the same when re-enabling the WAX220nnnnnn-CONFIG-ONLY passphrase, here on the already configured WAX220. Not convinced, this is intentional. Can DavidGo please check if this is correct, or the same passphrase set in place from the Netgear repository, based on the serial number?:
As expected, the computer Web UI is re-directed to the aplogin.net WiFi hotspot ...
...complaining about the invalid certificate, once allowed the exception ...
...we get the WAX220 Web UI with the AP Login Password prompt, which is the one we initially configured, but intentionally none of the ones printed on the label, too.
