mario_ed
Sep 21, 2023Guide
WAX220 initial configuration does not work
Today I bought two WAX220 (AX4200) access points and I tried to configure them. I connected two Ethernet with PoE. Network WAX220xxxxxxxx-CONFIG-ONLY came in. But when I tried to connect using the p...
schumaku
Sep 21, 2023Guru - Experienced User
The printed SSID (WAX220xxxxxxxx-CONFIG-ONLY) and wireless password, also from the QR code (including the SSID, the WPA2-PSK information, and the default WiFi access password), is valid for the initial configuration and for about 20 minutes only - and does not grant access to the LAN/network and the Internet. Following the factory default/reset again, It's intended only to open a Web browser session (on modern clients automatically, with some delay, to accept the self-signed certificate). Once you have defined your own password during the initial configuration, the printed password is no longer valid anymore.
Honestly, a little bit lost where you are struggling with the attempt initial connection and configuration.
mario_ed
Sep 21, 2023Guide
Thanks for your prompt reply.
Yes, your description matches also my understanding about how it should work. The problem is simple: the password written in the sticker does not work neither the QR code. I tried from my iPhone (QR code and manually) and from my PC (Dell XPS17), none of them works. I am getting a error message saying that the password is incorrect. I am stuck. Both brand new devices have the same problem.
How can I troubleshoot?
- May 21, 2023Retired_Member
