base9
Jul 17, 2023Aspirant
WAX220 WPA2-Enterprise help with VLAN?
I have 3 WiFi networks configured like so: ESSID_1 - 5gz only - WPA2-Personal - VLAN 101 ESSID_2 - 2.4ghz only - WPA2-Personal - VLAN 107 ESSID_3 - 2.4ghz and 5ghz - WPA2-Personal + fast roamin...
base9
Jul 18, 2023Aspirant
Thank you so much for looking into this.
My best guess as to what is going on is: When a management VLAN is configured and the Wifi networks are also configured with VLANs (Not sure if the Wifi VLANs are part of the issue or if it is only with management VLAN), some misbehavior occurs when the WAX220 tries to communicate with a radius server on the configured management VLAN.
This is why, in my troubleshooting, I made sure the radius was accessible on every VLAN, to see if the WAX220 was trying to contact the radius server over whichever VLAN is configured for the Wifi network - and based on the (malformed?) packet I see every time a client associates to that particular ESSID - this appears to be the case.
A frame that I think should be sent over VLAN 101 (the management VLAN) ends up getting corrupted(?) and sent over VLAN 107 (the VLAN set for the wifi network with WPA2-Enterprise enabled)
Now that I think about it. If a management VLAN is configured, the only IP assigned on the WAX220 would be whatever DHCP it got (or static) IP on the management VLAN - and so this naturally would be where I think the radius traffic would occur.
base9
Aug 07, 2023Aspirant
MikeD1234 did you ever get a chance to test this and see if our theory about the RADIUS traffic being corrupted and/or not sent over the management VLAN is what is happening?
- ErwinLAug 10, 2023NETGEAR Moderator
Hello base9,
If I may ask have you added the WAX220 as one of your RADIUS client in your Network Policy Server?
Erwin
- ErwinLSep 07, 2023NETGEAR Moderator
Hello base9,
Did I answer your question? In this case could you give us feedback on the situation and accept my post as a solution to make it more visible to other users?
Thanks in advance!
Have lovely day,
Erwin
Netgear Team
