minifreakmartin's avatar
Sep 23, 2024
WAX530 Wall Mount
Hello Community,
where can i get the wall mount for the wax630. mine disappeared after remodeling
1 Reply
  • You can check the official manufacturer’s website or authorized resellers for the WAX630 wall mount. If it’s not listed, contacting their support directly may help you find a compatible replacement or an alternative mounting solution.
ProSupport for Business
