Reinhof
Mar 31, 2024Aspirant
WAX610 Captive Portal taking 2 min to launch
Takes a long time for a (mobile IOS) user to get to the splash screen. Connects, then after a minute it says on the phone (No Internet). Then 2 mins later the splash screen show to accept the ULA a...
Reinhof
Thank you so much for the quick response. I can try OWE, but I'm wondering why this doesn't work out of the box? I have a bunch of small business clients that I want to install these at, but don't want to do any custom configuration (other than the captive portal options like graphic, welcome, EULA). Why do you think it doesn't work out of the box configured?
I did ready the firmware notes and the only thing that I'm not sure is an issue is that this SSID is on the management VLAN. Do I have to create a separate VLAN?
Currently - I have the basic captive portal configured. It takes 2 minutes to get the splash screen to come up and when it does, it just has a wifi symbol and an agree button - none of the graphic, welcome, EULA that I changed in the basic captive portal settings. Very frustrating.
