SteveMBarry
Apr 28, 2024Aspirant
wax610
I have a WAX610 and I can no longer log in to it. The Insight App. no longer works as it is a year old. I have tried logging in to the device from the browser but the standard "admin/password" does ...
- Apr 28, 2024
SteveMBarry wrote:
I fear that "does not work" could mean many things. What actually happens?
"Device failed to connect back" is what it comes back with and then tells me that An Insight Premium subscription is required.
Insight is something else. It is one of those Netgear services.
It has its own section around here:
NETGEAR Insight Network Management - NETGEAR Communities
I suspect that it is not relevant to you.
The reason for wanting to access the product is I get emails saying that there is a firmware update, which used to be handled by the Insight App., but I assumed I would be able to log in and do the update from there.I am not familiar with how Insight works. Emails about firmware updates are usually just marketing guff. The best way to check for updates it to use a web browser and the graphical user interface (GUI) and to look at the firmware version there. The look at the versions available in the support ages for your device.
Firmware updates are best done (in my opinion) manually:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
I will go on the business forum but why would the published admin/password not work?Depends on how you are going about it. Getting into access points isn't always straightforward. The router that sits between your AP and the outside world is in charge of accesa.
SteveMBarry
The reason for wanting to access the product is I get emails saying that there is a firmware update, which used to be handled by the Insight App., but I assumed I would be able to log in and do the update from there. I can't believe that I have to pay for a support package just to get firmware updates.
michaelkenward
Apr 28, 2024Guru - Experienced User
