Ken34
Nov 20, 2021Aspirant
WAX610Y As Client / Repeater
Is it possible to setup a WAX610Y as client or repeater on a non-insight 802.11AX mesh? I've been running two units, one root connected to a cable modem/router, and one as extender, with it also har...
Ken34
Nov 21, 2021Aspirant
Tried that last night, but link would not come up. Was showing the WAX610Y as the AP and not a Repeater. Channel matched up, securty was set correctly. Guessing maybe because it was hardwire connected to the internet and had an existing IP upon confguration. Only thing I haven't done yet is turn off DHCP server. Any further suggestions greatly appreciated.
-K
schumaku
Nov 21, 2021Guru - Experienced User
I'd suggest to put up a static iP to the device, connect by WiFi, or for the sake connected with an Ethernet cable to the WAC whie not configured to the other network. Needless to say, you need a fixed IP on your computer, too (lack of a DHCP srvice at that point) to be able to establish a network connection to what should become your WPA Repeater.
Not using such esoteric configurations anymore these days I'm afraid.
