ttcc
Nov 11, 2020Aspirant
WAX610Y INSIGHT ALERT: DEVICE OFFLINE-Channel Utilization went high ch1/Reboot reason: Crash
We just upgraded / replaced Orbi to these business WAX610 APs. We have NETGEAR WAX610 (qty4) and WAX610Y (qty 1) WiFi 6 Access Points at this location. This issue seems to have happend on the outdo...
RaghuHR
Nov 12, 2020NETGEAR Expert
- ttccNov 16, 2020Aspirant
HI RaghuHR, I DM'ed the solution as requested with the link to log file, LMK if you have thoughts on next steps.
Ted
- RaghuHRNov 16, 2020NETGEAR Expert
Thank you for sharing the logs. We are reviewing internally. Will update here what is our findings.
BTW - Are you still seeing those log messages & experiencing the loosing connection to Insight still ?
Have a good day!
Raghu
- ttccNov 17, 2020Aspirant
Hi Ragu
Yes it happens to reboot consistently 3 times a day since the new FW (prior it was only running for 2-3 days, but didn't see the crashing.
Also we updated all five WAX610 unites, we only have the one outdoor unit and thats the only one that crashes constantly.
Should I wait a day or so for a reply or should I also place a support call? I can run more diagnostic logs if it helps, but it looks all the same error.
Thanks
Ted
