StefanWauters
Jun 19, 2024Aspirant
WAX615 and 10.8.6.3 firmware
Does anybody experience problems after upgrading the firmware to 10.8.6.3 ? We have 2 devices who are on this version, and they are constantly disconnecting from the network.
schumaku
Jun 19, 2024Guru - Experienced User
Disconnect ... loosing the admin management, disconnecting and loosing Insight cloud connection (and not returning), or wireless clients loosing the association to and communication to the network?
StefanWauters
Network status becomes disconnected and looses communication with Insight cloud, then returns to connected after a while. This process keeps on repeating itself. (disconnect/connect/disconnect/connect....) the frequency varies: 5 mins, 10 mins, 30 mins...
This night, one of the devices was even deleted from the network:
The following device has been deleted from your network by Stefan Wauters
Details:
Device Name: begbg1wap05
Network Name: Groot Bijgaarden 23
Serial No: 6V31245RA006D
Model: WAX615
IP Address: Currently Not Available
I am 100% positive I did not delete it...
I had to add it again to get it back online.
- schumakuJun 19, 2024Guru - Experienced User
WAX615 on 10.8.6.3 operate rock solid here on my Insight installations, uptime up to 55 days 13 hours 20 Mins as of writing..
- BrianLJun 19, 2024NETGEAR Moderator
Hi StefanWauters,
Welcome to the Community!
Can you share the diagnostic file of both APs and enable TSM (see instructions here)?
Kind regards,
BrianL
