hunkofmonk
Jan 12, 2025Aspirant
WAX615 Inter-VLAN issue between clients across multiple SSIDs
As seen in multiple threads (supposedly resolved for other models): Solved: Inter-VLAN routing issue only via Wi-Fi - NETGEAR Communities https://community.netgear.com/t5/Business-Wireless/WAX630E-...
Help258
Mar 24, 2025Aspirant
I faced the same issue, but since it wasn’t a known problem, I contacted support. I followed their instructions, and my issue was resolved.
hunkofmonk wrote:As seen in multiple threads (supposedly resolved for other models):
An issue I am facing in WAX615 (currently on firmware v10.8.11.4)
With temporary 'allow-all' firewall rules:
Wired devices in any subnet can access Wireless clients hosted services on any VLAN / SSID.
Wireless clients in any VLAN / SSID can access any Wired device hosted services.
Wireless clients attempting to communicate with a wireless client in a different VLAN / SSID will not communicate properly.
The receiving device gets a TCP connection initiated but no SYN-ACK is forwarded to the client initiating the connection.
ICMP does respond properly between devices.
Can I get a status update on if this issue is present and known on WAX615 and if this can be resolved, or can support be in touch.
Mar 24, 2025Guru - Experienced User
Would be good to give details on what support had you do to resolve the issue you had.
- hunkofmonkMar 25, 2025AspirantI can confirm the issue still persists on Firmware V10.8.12.7
- hunkofmonkApr 30, 2025AspirantIssue still not resolved as of firmware version 10.8.13.2 https://kb.netgear.com/000066629/WAX615-Firmware-version-10-8-13-2
- hunkofmonkSep 05, 2025Aspirant
Issue still not resolved as of firmware version 11.8.0.9 https://kb.netgear.com/000068397/WAX615-Firmware-Version-11-8-0-9
