SteveAS
Mar 27, 2024Aspirant
WAX615 with strange internet behavior
Hi Guys, I have two WAX615 and tried different settings with Mesh and without Mesh, Static IP and dynamic IP, different DNS servers (external) ... but still have the same issues even after several Fi...
schumaku
Mar 27, 2024Guru - Experienced User
With both WAX615 powered over PoE, and connected to a switch - assuming the switch does provide access to the Internet infrastructure - what is the point to enable this Mesh more on one or both APs?
With fully wired WAX6xx only, none operating as a wireless mesh station, there is no reason to use the Advance Mesh Configuration.
Don't put the Mesh Mode to Auto, Extender Only, or Root Only. Keep it running with Disable Mesh
- SteveASMar 27, 2024Aspirant
Hi - the mesh was just for testing. the behavior still exist even without mesh.
- schumakuMar 27, 2024Guru - Experienced User
Swap the WAX615 for a test. In case the issue does move with the AP it might be a hardware issue, so head to https://my.netgear.com and file a warranty ticket. In case the issue is limited to one connection, You know where to look for.
