skeepee
Nov 01, 2023Follower
WAX620 2.4ghz network failing
The 2.4ghz network on my WAX620 keeps failing. Firmware is 9.6.3.2. During failure clients cannot see the associated SSID and cannot reconnect. Outages last 30+ minutes. Power cycling the WAX620 ...
schumaku
Nov 01, 2023Guru - Experienced User
When I'm reading Sonos speakers .... STP comes into my mind. Is STP (Spanning Tree Protocol) enabled on our access points and the switches making up the wired backhaul for the WAX6xx?
For your reference: Configure STP settings to work with Sonos
How comes the firmware is stuck on a one year old build, updated several times since?
