IgorB
Jun 22, 2023Tutor
WAX620 SNMP seems doesn't work
Hi, How I could query a wifi client list on WAX620 via SNMP? AP in a local mode, Firmware V10.4.1.4
schumaku
Jun 22, 2023Guru - Experienced User
Simply put: You can't. Netgear abandoned the former Netgear Private MIBs in place on the WAC6xx, WAX6xx including the MIB tree above .1.3.6.1.4.1.4526, and for the sake of the WAX214 and he WAX218 in a complete different implementation - without a proper substitution. Available are bunch of RFC standard MIBs only.
DavidGo please forward this to the project manager in charge to bring back the basic Private MIBs - in the scope what the competition in the MIB range from 1.3.6.1.4.1.9.9.521 does have available for years.
IgorB
Jun 22, 2023Tutor
Thank you for clarifying that.
Hopefully I will be able to return all AP, what a surprise.
- schumakuJun 22, 2023Guru - Experienced User
I hope this isn't needed. This fix should not be a difficult thing, because all information required is readily available on the WAC6xx and WAX6xx platforms.
- IgorBJun 22, 2023Tutor
If it's related to the whole WAX6xx platform, there are other posts here from 2021 complaining about similar issues with WAX610.
Realistically nobody will commit to fix it.
- pk0627Jul 26, 2023Aspirant
I was worried about facing this problem.
I don't understand why NETGEAR is leaving this problem unattended.
Hope the problem improves.
