IgorB
Jun 22, 2023Tutor
WAX620 SNMP seems doesn't work
Hi, How I could query a wifi client list on WAX620 via SNMP? AP in a local mode, Firmware V10.4.1.4
IgorB
Jun 22, 2023Tutor
Thank you for clarifying that.
Hopefully I will be able to return all AP, what a surprise.
schumaku
Jun 22, 2023Guru - Experienced User
I hope this isn't needed. This fix should not be a difficult thing, because all information required is readily available on the WAC6xx and WAX6xx platforms.
- IgorBJun 22, 2023Tutor
If it's related to the whole WAX6xx platform, there are other posts here from 2021 complaining about similar issues with WAX610.
Realistically nobody will commit to fix it.
- pk0627Jul 26, 2023Aspirant
I was worried about facing this problem.
I don't understand why NETGEAR is leaving this problem unattended.
Hope the problem improves.
