pgw85706
Mar 08, 2023Tutor
WAX620
Hello. I need to strengthen my wireless coverage in our 3 story home. Please confirm to install 1 WAX620 on each floor (3 total) connected to a GS308EP PoE+ (123W) switch are compatib...
michaelkenward
Mar 08, 2023Guru - Experienced User
pgw85706 wrote:
Hello. I need to strengthen my wireless coverage in our 3 story home. Please confirm to install 1 WAX620 on each floor (3 total) connected to a GS308EP PoE+ (123W) switch are compatible.
Connect to what router?
You want to wire these repeaters as Access Points to a GS308EP switch?
Why did you pick network managed devices from Netgear's business range? From messages that appear here, they don't always sit nicely in domestic environments.
A more common choice would be a Mesh system that can create a seamless WiFi network.
pgw85706
Mar 08, 2023Tutor
The switch will connect to a Linksys EA8500 router (for now).
You want to wire these repeaters as Access Points to a GS308EP switch? That is my thinking unless there is a problem with this config.
Why did you pick network managed devices from Netgear's business range? I am seeking a rugged, industrial grade configuration. I like the coverage and range of the WAX devices. All APs will be installed with hardwire ethernet cable back to the switch. I am working to hardwire all my "fixed" devices....TVs, printers, LAN storage, pool control, etc to reduce the wifi load.
I have studied the mesh network offerings promoted for home applications. They seem priced high to me and the WAX devices seems like a stronger, more cost effective solution.
- BasuKhodanapurMar 09, 2023Apprentice
Hi Patrick
Thanks for writing to us.
Could you please share below details, we can help you in no of AP's required to cover 3 story home.
1. floor map with measurement
2. No of clients you are planning to connect to each WAX620 AP.
3. Any other particular requirement.
Best Regards,
Basu
- abacqdghfthMar 09, 2023Guide
Netgear has a no obligation and free wifi planning services. the team of experts will use industry standard wi-fi survey and planner software to estimate the number and placement of APs and send you an report.
please check out
https://www.netgear.com/av/services/prowifi-designsupport/
and send an e-mail today. someone will contact you in soon.
- pgw85706Mar 10, 2023Tutor
Thank you. I will make a submittal and see what happens.
