vexingv
Jun 21, 2022Follower
WAX630 - 2.4ghz radio only SSID, constant client disconnects or undiscoverable wifi/SSID
I have set up a new WAX630 access point (firmware V9.6.3.2) to replace the wireless portion of my existing wifi/router setup (Asus RT-AC3200 using custom Tomato firmware but will eventually be replac...
DaneA
Jun 23, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
Since you have already done a factory reset a few times and still the same problem, I suggest you to open a support ticket with the NETGEAR Support Team here at anytime for further investigation. Kindly state your concern as well as you may include the link to this post.
DaneA
NETGEAR Community Team
