benoit_fr's avatar
benoit_fr
Apprentice
Oct 09, 2019
Guest Wifi SSID
Hi,
Would that be possible to set the same guest wifi SSIDs, such as for non-guest, in both 2,4Ghz and 5Ghz in the next firmware ? (and not SSID_name and SSID_name-5ghz)
Model : RAX40.
Many thanks.
Benoît
  • Done thanks.
    So you mean that's it's not a bug but a feature request ;)
    Best,
