benoit_fr
Oct 09, 2019Apprentice
Guest Wifi SSID
Hi, Would that be possible to set the same guest wifi SSIDs, such as for non-guest, in both 2,4Ghz and 5Ghz in the next firmware ? (and not SSID_name and SSID_name-5ghz) Model : RAX40. M...
- Oct 09, 2019
Done thanks.
So you mean that's it's not a bug but a feature request ;)
Best,
benoit_fr
Current Firmware version : v....60_1.0.1
- plemansOct 09, 2019Guru - Experienced User
you can try suggesting this in the suggestion forum.
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
- benoit_frOct 09, 2019Apprentice
Done thanks.
Best,
