matthew009's avatar
matthew009
Follower
Jul 17, 2023
WAX630 - Change IP and connect existing network
Hello,
I'd like to set up WAX IP(like 192.168.11.x)  as different from Router(192.168.1.x) and share data from all devices connected with router.
Could you help me how to set up this?
Thank you in advance,
MT.
1 Reply
  • schumaku's avatar
    schumaku
    There is a NAT mode option allowing to have a single, local SSID NATed many2one onto a single LAN IP address, see the NAT Mode shown in the fine Insight Managed WiFi 6 AX6000 Tri-band Multi-Gig Access Point Model WAX630 User Manual on p.205 ff. Keep in mind these makes up a fully isolated IP subnet, intended to provide basic Internet access to the SSID, but no further communication or subnet access. Useful for some kind of Guest or BYOD deployments only..
ProSupport for Business
