dunnjo
Dec 04, 2023Aspirant
WAX630 & WAX620s
I have 3 APs. WAX 630 and 2 WAX620s all root APs meshed together. All year these have worked generally well with minor annoyances here and there. On Nov 6th, that all changed. it started with not...
schumaku
Dec 05, 2023Guru - Experienced User
Do we face a wired network with three AP, or really a wireless Mesh?
If it's an all wired network, having Mesh enabled does not make any sense. The only exception is if you intend to operate one or more WAX6xx as wireless satellite(s)-
dunnjo
Dec 05, 2023Aspirant
They are root APs because Mesh Technology is set to Auto. This has always been the setup from day 1 without any issue. Nothing changed, so this really has no rhyme or reason.
- schumakuDec 05, 2023Guru - Experienced User
Not what I have asked for my friend.
- dunnjoDec 05, 2023AspirantProvided you the setup. If they are all root APs, then yes, they are still wired back to other switches.
As you have no intention to operate any WAX6xx under a pure Netgear Insight Instant Mesh (==wireless backhaul), what's the point to keep the Auto mode enabled? I would suggest to disable it. To much marketing about Mesh systems?
No idea if this will magically resolve the problem that your WAX6xx cant reach the Insight cloud.
