justkaka's avatar
justkaka
Follower
Aug 07, 2022
Wax630 at Two Physical sites
Have two sites - physically seperate Town/City
At both site we have Draytek 2866 Routers, Sites are conected via SITE-SITE VPN on the Draytek Router
At the Main Site we have a Windows Server 2012 with DHCP
The Satalite site's Router has a different IP but DHCP users at this site pick up IP from Servers DHCP  at the Main site
Existing Wifi set up - consists of Staff and Guest SSID (guest has no access to LAN)
NO VLAN's setup - never really setup VLANs
On the WAX630 - I want to keep the Staff and Guest Networks separete ie. guest have no access to LAN or other Wifi devices
I've created Guest and Staff SSID - guest as ISOLATED
Currently I've set this up for the Main site on 2 x WAX630's at Home
The other two access Points for the Satalite site will use the same SSID's ?
I'm not sure have to Test that but...
Technically if I add the other 2 devices at home I'm guessing that should work in a similar way (although my Virgin Router provide the DHCP)
Appreciate any comments / feed back.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Business Wireless - NETGEAR Communities
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
ProSupport for Business
