Jhab
Apr 11, 2025Aspirant
WAX630 connection problem after changing management from Insight to local
Hi, I have 3 WAX630 with expired Insight subscription. I want to manage them locally. I log into the web-admin and change the management mode to local. On Save the box says it is applying the cha...
Jhab
Hi Kurt!
Thanks for the link. I removed the device from Insight using the local management web interface.
Wether or not this leads to a factory reset of the device, as I could not connect to the device (athough the configured SSID spun up) I did a factory reset. This leads to the creation of the setup wlan, which I could use to connect and configure the device. After that I again could not connect to the WAX…
Thanks for your help, best
Jochen
schumaku
Apr 12, 2025Guru - Experienced User
Whether or not this leads to a factory reset of the device, as I could not connect to the device (although the configured SSID spun up) ...
...so it does not a factory reset, otherwise the configured SSIDs would be gone among other settings.
This setup wlan does remain active for about 30 minutes from the start-up if wally brain is right.
A little vague for a problem description.
Unable to establish a wireless connection using the previously stored config eg. on a mobile or a notebook? Keep in mind that you have to "forget" the wireless config if changing even minor things, otherwise the connection won't be established.
I'll be online over these days, keeping an open ear of course.
Happy weekend dear Jochen!
-Kurt.
- JhabApr 12, 2025AspirantHi Kurt,
Sorry for being vague… after saving initial setup, the configured wlan is there and can be connected to. But there seems to be no backend connection. I cannot spot the WAX on my net and the existing DHCP server does not issue an IP for the client. So: wlan but no Internet.
Best, and thanks again
Jochen- JhabApr 12, 2025AspirantI should add that I set my DHCP-Server to always issue the same IP for the Wax. When setting the WAX to factory defaults, this works as expected.
- schumakuApr 13, 2025Guru - Experienced User
Jhab wrote:
I should add that I set my DHCP-Server to always issue the same IP for the Wax. When setting the WAX to factory defaults, this works as expected.This is "just" something like a reservation of the MAC address to the IP address to be issued on the management VLAN.
Have defined to the SSID a VLAN ID which does not exist on the trunk where the WAX630 is connected to?
Or does that VLAN configured not have a DHCP server in the same broadcast domain?
Does that VLAN and it's subnet not have NATed Internet access through the router?
