JJEIT
Aug 08, 2024Aspirant
WAX630 disconnection issues
We purchased a NETGEAR® Insight Managed WiFi 6 AX6000 Tri-Band Multi-Gig Access Point (WAX630) a few months ago and ever since we installed it we've been getting disconnection issues when users conne...
mcfarlak479
Dec 18, 2024Aspirant
I had the problem on 10.8.11.4. I rolled back to 10.8.8.6 and still have the issue.
I have sent several logs to pramendra singh. I have not heard anything back.
Thanks
KMC
RennaD
Dec 19, 2024NETGEAR Moderator
Hi mcfarlak479,
Can you please describe the specific issue you are having and also kindly answer the following:
1. How many WAX630 are you using and how far are they from each other?
2. Does client disconnect all at the same time?
3. How often does disconnection happen?
4. Is issue happening only to specific clients? What is the make and model?
5. Are/Is the AP managed locally or via Insight?
Have a lovely day,
RennaD
Netgear Team
- mcfarlak479Dec 29, 2024Aspirant
1. I am using 8 WAX630 APs. They are 50ft - 100 ft apart. All separated typically by walls.
2. There are several clients that disconnect. Not all the same clients just random. I do believe that when a disconnect happens it is sometimes several clients at the same time.
3. Random disconnects. Seems to happen more with a larger number of clients online.
4. No specific clients. Brother 810W printers, Apple iPads, Mac Books, Samsung TVs..
5. All APs are managed via Insight.
Thank you.
KMC
- ErwinLJan 16, 2025NETGEAR Moderator
Hello mcfarlak479
I just have few questions below:1. Do you have VLAN configurations?
2. Are your APs powered over Ethernet?
3. Do you experience wired disconnection or slow network as well when the issue happens?
4. Are the wireless devices comes back connected after some time?
5. Were you able to observe if the issue of disconnection happens either only or both 2.4, 5GHz or 6Ghz frequency?
6. What model of switch are these APs connected?
7. Have you tried testing on a stand alone device and check if you will still have the same issue?
Have a lovely day,
Erwin
Netgear Team - mcfarlak479Jan 17, 2025Aspirant
Greetings, Here are the answers to your questions.
1. Do you have VLAN configurations? No VLANS
2. Are your APs powered over Ethernet? Yes
3. Do you experience wired disconnection or slow network as well when the issue happens? No
4. Are the wireless devices comes back connected after some time? Yes, Devices do come back just a few seconds later.
5. Were you able to observe if the issue of disconnection happens either only or both 2.4, 5GHz or 6Ghz frequency? No
6. What model of switch are these APs connected? GS752TPv2
7. Have you tried testing on a stand alone device and check if you will still have the same issue? No - ErwinLJan 20, 2025NETGEAR Moderator
Hello mcfarlak479
Would you be able to DM me your network diagram? How often do you get the disconnection in a day? Please try also creating a new location and move at least one AP there and observe if the issue is the same.Have a lovely day,
Erwin
Netgear Team
