ivankhoury
May 27, 2017Aspirant
Disconnecting issues
I've had this problem for quite a while with this new router firmware... the router will randomly disconnect certain connections (like my game and whatsapp) for like 10-20 seconds (but the rest of the network works perfectly fine) and then reconnect, after a few minutes before repeating the same cycle. This issue never happened with other routers I've had or with this router with an older firmware, so I am 100% certain it's the firmware causing this.
Maybe it's connection timeouts? QoS? I don't know, that's why I am asking if there's anything I can do in the router settings that might solve these random disconnects. I tried rolling back the software but it doesn't allow me to rollback.
My router is VEGN2610 - https://www.netgear.com/service-providers/products/telco/gateways/vegn2610.aspx
The previous firmware was 1.0.0.27, and the new problematic one is 1.0.0.35:
The firmware has to match the hardware of the modem/router (gateway) any third party firmware that controls the modems settings and allows it to work with your isp has to be support by them. Not a easy thing to find .
If you are lucky you may be able to the modem/router reflashed to a older version at a cost by netgear never heard of this before but the worst they can say is no.
You have two of them so the unit to sent them is no problem if they will do it good luck with question to them.
- William10aMaster
Have you tried the older firmware to see if the problem goes away?
- ivankhouryAspirant
Yes, I've had the same router but with an older firmware and it had no issues, the moment my ISP updated it for me the same issues came back. I'm now stuck with the same router which I cannot rollback.
- William10aMaster
Can your isp back flash the the unit to the older version that worked as their version of the firmware does not work for you?
I understand they want to keep the modems on their network the same firmware but there seems to be a issue when ot comes to your service and the older version worked.
I was wondering, can I install a different firmware from Netgear on my router? Firmware meant for another router, or a universal firmware?
- William10aMaster
