mattore
Aug 10, 2022Aspirant
WAX630: MIB not found
I wanted to check out the SNMP functionality of the WAX630 and Netgear provides a download here for the MIB: https://www.netgear.com/support/product/wax630.aspx#download Unfortunately the lin...
- Aug 11, 2022
Welcome to the Community!
I tried checking the link, instead of letting you download the .mib file it displays the content. You can always right click on the page and Save Pag As. It should let you save the mib file.
Alternatively, you can copy the text from the page, paste it on notepad and save it as mib. You can try using this file.
HTH
Marc_V
Aug 11, 2022NETGEAR Employee Retired
HTH
