alxkkbrg
Oct 25, 2021Aspirant
WAX630 stuck on "mode a"
Hi everyone I have a problem with a WAX630 AP running a low 5Ghz broadcast: No matter what channel (36-64)I select, no matter what wireless mode (a to ax) I select or even channel width (20/4...
- Oct 25, 2021
I did a factory reset which solved the issue. Thanks for your help.
alxkkbrg
Hi everyone
Thanks for your replyes. It is a fresh setup of both APs after a factory reset this morning. So far it worked well. I managed to set up the two APs I've got thanks to your help, Kurt.
According to the APs dashboard firmware V9.5.3.4 is installed. I've just checked, there is no later firmware available.
I was trying to set up Vlans this morning but failed to connect them to the internet, so I reset everything to the beginning. The only thing I did not reverted to the initial state was the set up of 3 different SSIDs for different types of devices.
Other than that I connected the two APs via WDS, and thats it. Other than that there is nothing special set up yet. I wanted to have a solid running network before starting to "experiment" and customize it further to my needs.
Would you suggest to factory reset the AP again? I got quiet good at that over the past couple of days :) Or do you have any other idea what I could do?
Best wishes,
Alex
schumaku
Oct 25, 2021Guru - Experienced User
This is beyond of what the WAX630 or the GC510P can do - each VLAN does make up a dedicated, isolated network - and some router must exist for the routing and the Internet connection.
WDS - what for please? Aren't both APs on the same wired network, powered from that very same GC510P?
I've put up some pointers to Tw and California Netgear reps to this thread already.
Grüsse aus der Schweiz,
-Kurt.
PS. Afraid, I have no WAX630 at hand for testing here.
- alxkkbrgOct 25, 2021Aspirant
Hi Kurt--
Just one AP is wired to the GC510P (which is connedted to a BR200 router, which is connedted to the internet) the other AP should extend the WiFI and bridge the network with a dedicated backhaul and be also connected to a switch (GC110p) to hardwire more devices.
You are the best. Many thanks!!!
Grüsse aus der Schweiz,-Kurt.
Best wishes--
Grüsse aus Düsseldorf
Alex
