alxkkbrg
Oct 25, 2021Aspirant
WAX630 stuck on "mode a"
Hi everyone I have a problem with a WAX630 AP running a low 5Ghz broadcast: No matter what channel (36-64)I select, no matter what wireless mode (a to ax) I select or even channel width (20/4...
- Oct 25, 2021
I did a factory reset which solved the issue. Thanks for your help.
alxkkbrg
Hi Kurt--
WDS - what for please? Aren't both APs on the same wired network, powered from that very same GC510P?
Just one AP is wired to the GC510P (which is connedted to a BR200 router, which is connedted to the internet) the other AP should extend the WiFI and bridge the network with a dedicated backhaul and be also connected to a switch (GC110p) to hardwire more devices.
I've put up some pointers to Tw and California Netgear reps to this thread already.
You are the best. Many thanks!!!
Grüsse aus der Schweiz,-Kurt.
PS. Afraid, I have no WAX630 at hand for testing here.
Best wishes--
Grüsse aus Düsseldorf
Alex
alxkkbrg
