jtm0n3y
Jun 27, 2022Tutor
WAX630E AXE7800 POE Unacceptably SLOW
I have a very basic setup - 1gig coax/cable ISP service running to a FortiGate firewall, from the firewall I have an uplink with two VLANs tagged to an MS108EUP switch, from that switch I have POE++ ...
- Jun 27, 2022
Putting the AP on a separate management VLAN that wasn't a part of any of the SSIDs VLANs resolved this slowness issue. No idea why it resolved it or why it caused the issue to begin with. But speeds are back to "acceptable" now.
jtm0n3y
Jun 27, 2022Tutor
douglas_cheung
Aug 04, 2022NETGEAR Expert
I am glad you resolved the issue... but I am still not perfectly satisfied, without knowing the root cause.
Doug
